Brf 2004r ck performance stage 1
chris718
BILLET SERVO,BILLET DRUM,BILLET ANCHOR PIN,ALTO WIDE BAND,NEW GM PUMP,Shipped anywhere in the cont USA 1699.00.All original brf core,valve body ,governor and case.555 bost valve and sump extension with bottom feed pickup.All new clutches ,stels ,bushings,washers,paper ,rubber ,rings etc.In car tested ,work perfect.
will add billet input shaft ,ring gear and carrier for 599.00.stage 2 specs
Chris, Tried to call you a several times since I posted on your other thread. 1st several times I think I was getting your fax machine. Anyways what I was wanting to know is how much for the trans if a brf core is provide or the cost to build mine to this spec? Currently I have two cores setting around & I really don't want another from buying a trans straight out.
Can reply PM or email....
Anyone who didnt get in on this can give me a ring and Ill see what I can do .Have a few units.
