trick86
Solid Member
- Nov 9, 2009
I produced around a dozen of these a few years back, there are only a few left so catch one while you can. $249 plus ride, Paypal add 3%.
BRH Turbo Buick's 86-87' Turbo Buick and Grand National Transmission Cooler Kit
Is your 200-4R prepared to deal with the heat dissipation requirements of a street/strip Turbo Buick V6?....
This kit is truly a bolt-on unit for your 86-87' Turbo Buick and Grand National using a custom designed cooling assembly. No hose clamps here, custom cooler lines featuring 5/16" 45 degree flare fittings to make plumbing connections just like the factory should have. Also, this kit is complete with a "one of a kind" water-jet cut bracket to keep appropriate clearance from the AC condenser and is finished in powdercoat satin black. 100% North American made units featuring LPD Technology (Low Pressure Drop), a unique design that allows cooler, thicker ATF to flow more efficiently through two open bypass channels positioned at the top or the cooler. As operating temperatures increase, the ATF becomes hotter and thinner. It's then directed through the core where it's cooled. This highly efficient cooling technology combines improved protection against lube system failure with optimal heat transfer. High efficiency Plate and Fin design which has 30% more cooling and 15 times less flow restriction than tradition tube and fin designs. This particular cooler offers a GVW rating of 20,000 and a BTU cooling capacity of 16,000. As well, custom hardware and detailed installation instructions are included. This is the most complete kit available for your Turbo Buick to date and all components finished in black blending in perfectly with the rest of what lays behind the grill.
If you have any questions regarding this product please don't hesitate to contact me at: trick86@live.ca
