Brian Good Guy !
wickedtt
i got a extra large high performance tranny servo from a fellow board member (board name brian ) and it works flawless.it took 10 minutes to install and my tranny now shifts nice and firm barks the tires again flawless .its a nice custom made one that is 33% larger than the GN`s 694. Not 11% bigger like the billet servos out there. You will not get the downshift clunk with this servo either. It will really raise shift firmness in any gear. You will be pleased, and suprised by the difference.i would recommend brian, you can contact him at :
hipsibri@cs.com
:D
Did you have a problem after your new rebuild, where you were having problems w/ the 1-2 shifts? This servo cure that problem?
well my shifts were soft after i installed a smaller high stall converter (vigilante 9.5 lockup).i installed the servo in 10 minutes and the shifts were crisp again. made a real nice difference most of all it was easily done.no b.s. they flat out work!
