GangsterMD
Turbo'd since '95
- Dec 29, 2007
Not sure the correct terminology, but the set screw that holds the pin in the diff carrier broke
I was trying to install new longer wheel studs, and there wasn't enough room behind to get the longer studs in. So I figured I'd just pull the diff cover, pull the pin out, and slide out the axles... Not a good start. Has this happened to others? The problem I see with using an extractor is there isn't enough room to drill straight into the hole
If I drill in crooked, the extractor will go in crooked. Also what's that "S" looking thing around the pin? I've never had the axles out of this car - just changed the fluid. I guess the other thing would be a clue of how to get the studs in, then I could just put the set screw back in and fight that battle another day.
