Broken carrier pin set screw
GangsterMD
Turbo'd since '95
Not sure the correct terminology, but the set screw that holds the pin in the diff carrier broke :mad: I was trying to install new longer wheel studs, and there wasn't enough room behind to get the longer studs in. So I figured I'd just pull the diff cover, pull the pin out, and slide out the axles... Not a good start. Has this happened to others? The problem I see with using an extractor is there isn't enough room to drill straight into the hole :confused: If I drill in crooked, the extractor will go in crooked. Also what's that "S" looking thing around the pin? I've never had the axles out of this car - just changed the fluid. I guess the other thing would be a clue of how to get the studs in, then I could just put the set screw back in and fight that battle another day.
It's common for the retaining bolt for the pin to break. There is a kit available from MATCO part# DPK1 for removing the broken bolt. The "S" shaped piece is a preload spring for the clutch packs.
You guys are awesome, I'll get a kit. As for the clutch preload spring, any tricks when I get the pin out?
easy way to put the studs in is to drill a hole in the backer plate (there is room )
this way if you snap one (or all five :eek:) you can replace them at the track with just a hammer
Yeah don't pull out that S spring either because trying to put it back in is a PITA!
DONT TURN THE WHEELS ONCE THE CROSS PIN IS OUT THE SPIDER GEARS WILL TURN. This is a real pain to get back realigned
Ok so Diffs 101 here. Isn't there "C" clips in behind/beside the clutch preload spring? If you don't want to remove the spring, how do you get the "C" clips out, in order to pull the axles? I'm starting to like the idea of drilling a hole in the backing plate.
push in the axles one at a time and use a magnet and you can pull the axels out.
JD
Cross shaft pin out, then cross shaft.
Push in on axle and use a mag pickup to get the c clips off/out
