Bruce, can i have more?
Windy6
Bruce, I raised my line pressure to 250 psi and the trans shifts much better. But 2-3 is still not as firm as i would like. Is 280-290 psi too much? What are the downsides to raising it that high?
I can tell you this about line pressure. In the 2004r with the parts that are available I have not found a downside to line pressure in the 300 range. I set all my trannys up to operate in this range. I have seen the rotor break from pressure in the 4L60 and 700. So to be on the safe side I had 20 4340 billet rotors made to be sure there are no problems and will install them in all my performance builds. 250 psi is plenty of line for most apps and with a properly set up 3rd gear circuit should have a good 2-3 shift firmness.
1+1=2
Lonnie, Bruce......Same thing :D ROFL
Thanks Lonnie...;)
BT
Sorry about that Bruce. With the comp down for over a month I just had to answer a question. hehehe
SORRY?
SORRY? I meant that in the most positive of ways. You know better than that. THANK YOU!!! We need you here doing just that. Answer questions. All you can.... Thanks again...
Help............please......:)
