Does anyone have wiring diagram of the plug-and-play harness for GN that Precision sold/sells?
I have contacted Precision and Bigstuff but neither has any schematics of the "BV6" build.
The issues are:
1) Where to contact knock module. I have some vague info that it should go to 4th connector X1 witch is marked "SWA"
2) Y2 on the 4th connector that is marked "ASD Sense(Viper)" is also wired to BS3 but other end is not connected to anything. What this can be used for?
3) Y1 on the 4th marked "TOT" is going to LOG connector pin E. What this can be used for?
4) T2 on the 4th marked "fuel pressure" is going to LOG connector pin B. Is it really fuel pressure input, since the box does not have DAE. It only has BASE BV6 DAI.
Thanks in advance.
The issues are:
Thanks in advance.
