BSTC Boost Controller Mounting
chiphead
TB.Com Webmaster
Guys,
I bought a used BSTC Boost Controller and have no idea where to mount it. It doesn't even look like there is a way or if it came with a mounting solution. Where should I put it? Will I be ajdusting it alot?
Now I don't want to put holes in the dash or anything the car is in perfect condition. No double sided sticky tape either.
Anyone have a slick mounting solution? How about posting some pics on how you did this too?
Sorry I have to crop out some things that nobody needs to see.
I put mine in the ashtray area of the console after removal of the ashtray in the very rear of that area. I had to slightly modify the chrome area there with a dremel tool grinder and oriented the bstC it so it's in the vertical position. I did have to find a lower profile knob and found a rubber one I like so to have full closure of the door there. The stock length wiring was sufficient to reach and I routed everything hidden and out of the way for a clean install. I then fabbed up an aluminum beauty plate to place in the 2 screw position in front of the unit and covered the plate in silver faux carbon fiber material. Sorry- no pics since my PC crashed and I'm on a laptop now. I don't have the digicam software loaded on this machine.
You might want to call them up. They might not sell them anymore im not sure who sells them besides fullthrottlespeed.
