chopped39
- Aug 30, 2004
The block check needs to be done in the radiator. Drain coolant 4 inches below cap and try again with car running. Easy test is to pull spark plugs and pressure test system. Let it sit for an hour and then turn engine over by hand and watch for coolant at spark plug holes.
That test works every time. Do the block check one more time but at cap of radiator but make sure you drain some coolant because it will mix with liquid. If its that bad of a leak you wont have to pump the bulb on the tester.
The other test would be an air lift test. This test pulls a vacuum on the system. You pull it to 25inches and let it sit .It should stay. good luck. I missed the part where you did test in radiator sorry.
