Thanks Dusty.. i'm in the process of doing mine.. those shocks and the word budget
Instant center set on firewall or drivers seat?
Did you redrill the lower control arm mounts? I ask cause on a 275/60 tire its hard to get the rear down enough with factory tubs to get the lower control arm parallel with the ground. So one way is to move down the mounting point on the lower box..
Back springs using a coilover on the DA shock or using 4 cyl springs?
Looks great leaving..
