Lee Thompson
- May 24, 2001
Has anyone run into or heard of a problem keeping a Buick seal in a Stage motor from leaking? I have an older Stage block that takes a Buick seal. I have put 2 in in less than 100 miles. The crank is the correct dia. for a Buick seal. Both seals were new (Felpro) neophrene. It is coming from around the seal and not the side seals. Also what is the purpose of the flange on the crank between the bearing and seal? The eng. is going to have to come back out, so if someone can shed some light on this, I will be forever indebted to you.
