Buick V-6, oddfire, turbo and TBI
Discussion in 'Members Rides, Friends and Family' started by gdouaire, Dec 25, 2013.
  1. gdouaire
    gdouaire
    Expand Collapse
    Aug 9, 2013
    110
    3
    Offline
    Once the board has its power supp ready, you can connect it to the stimulator and verify voltage on the main board. This is as per the assembly manual. OF COURSE my board isnt working as expected. Tomorrow's another day. Another testing day.
    #21 gdouaire, Jan 19, 2014
  2. gdouaire
    gdouaire
    Expand Collapse
    Aug 9, 2013
    110
    3
    Offline
    Will resume working on this during next winter. Right now focusing on the Cutlass itself - brake job, etc.
  3. liquidh8
    liquidh8
    Expand Collapse
    May 17, 2006
    619
    20
    Offline
    I'll be following this thread for sure.
  4. COOPER12
    COOPER12
    Expand Collapse
    Sep 17, 2011
    218
    10
    Offline
  5. gdouaire
    gdouaire
    Expand Collapse
    Aug 9, 2013
    110
    3
    Offline
    The odd V6 engine is now in my basement, for a winter build. Did not have the cylinder honed or bored - they are perfect. Will reinstall stock crank, rods with new pistons.
    Finally found all the hardware to install thr Isky TurboCycle camshaft.
    Also found a "Hoof" timing set. Much beefier than the OEM setup.
    #25 gdouaire, Nov 13, 2014
  6. Street Lethal
    Street Lethal
    Expand Collapse
    Tech Anarchist
    Oct 8, 2006
    2,284
    96
    Offline
    Nice build, coming along nicely. Was messing around with TBI in a 3rd gen years back myself, I pulled the stock throttle body and modded it to increase air flow, didn't want to go the 454 throttle body route. I essentially cut down the center wall, and fabricated my own butterfly. The vacuum port that runs through there was filled with aluminum. I went a little further with it later down the road, as I replicated a blow thru carb with it and was intending on running it with a dual plenum intake manifold with injector bungs welded in and turbo charger, but I decided on going TPI soon after, so the project came to a halt...
    [​IMG]
    [​IMG]
    #26 Street Lethal, Jan 20, 2015
    • Like Like x 1
  7. liquidh8
    liquidh8
    Expand Collapse
    May 17, 2006
    619
    20
    Offline
    Nice, I too was messing with the TBI, using the EBL Classic as soon as it was available. I went the 454 TB with 90lb/hr injectors, vac ref FPR, and a 150 horse sniff of gas (+more).
    Hope you winter build comes along nicely, I have been watching this thread!:)
    • Like Like x 1
  8. gdouaire
    gdouaire
    Expand Collapse
    Aug 9, 2013
    110
    3
    Offline
    It's been a long time, && many things have happened! I had piled up so many parts. Can't go quit on this project :)
    Started by completing by assembling the crank, piston and camshaft.
    Next up: heads. porting to complete, then re-assembly.
    #28 gdouaire, Dec 31, 2017
  9. 1986 Buick GX1
    1986 Buick GX1
    Expand Collapse
    GX1 #001 [The One and Only]
    Apr 24, 2015
    797
    82
    Offline
    Way to keep after it. Kudos!
  10. gdouaire
    gdouaire
    Expand Collapse
    Aug 9, 2013
    110
    3
    Offline
    IMG_20180113_111106.jpg Will likely install the original 2-barrel carb for the initial startup..
  11. gdouaire
    gdouaire
    Expand Collapse
    Aug 9, 2013
    110
    3
    Offline
  12. gdouaire
    gdouaire
    Expand Collapse
    Aug 9, 2013
    110
    3
    Offline
    The engine is coming along nicely. I ran the oil pump, works fine; need to run it again with a pressure gauge.
    next up: installing the manifold; rebuilding the 2BBL carb.
Share This Page
