Build questions
Tim King
I just bought a 86 GN and wanna add some power so I bought a t67 turbo. What else do I need for this to work? I'm planning on adding a front mount IC. What injectors, chip, ect do I need. I was also wanting to add some headers, which ones should I get? Also, I have the engine and trans out right now and it has 97k on it, anything else I should do while it's out? Thanks for your help.
First u don't need headers I know people well into the 9s with the stockers. As to ur chip deal people will tell u multiple things from tuerbo tweak to red armstrong but my personal opinion is spend the money and buy fast XFI. Go to hartline performance and if u buy it from him its lifetime tuning and tech. He has it alone or with injectors. That unit is so easy to use and there is tons of possibilities by using it. As far as doing anything else a converter wouldn't hurt and if the engine wasn't bad when pulled I wouldn't waste the money there. Just my .02
x2 on the stock headers. At the very least you need to upgrade the fuel system to a Walbro 255 pump and a hotwire kit. The chip & injectors you can get from Eric at turbo tweak. While it is out, I would change the valve springs for good measure.
