Oct 28, 2010 #1 B buickgn87 Banned Joined Mar 23, 2010 Messages 208 109 3.8L My pistons specify they are for a 5.960" connecting rod. I have a set of connecting rods that are 5.970" Can I run these?...I'm assuming the engine will have slightly higher compression ratio. Thanks, Jason
Oct 28, 2010 #2 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 I don't see why not. As long as you have enough deck height and the piston doesn't come out of the hole at TDC you should be ok.
Oct 28, 2010 #3 D dr_frankenstein Mad Scientist Joined Mar 17, 2008 Messages 5,126 are these rods actual buick rods? or are these a set of SBC rods? A.j.
Oct 28, 2010 #4 B buickgn87 Banned Joined Mar 23, 2010 Messages 208 dr_frankenstein said: are these rods actual buick rods? or are these a set of SBC rods? A.j. Click to expand... Yes, SCAT 4340 H Beam - Mfg part #: 2-3.8-5970-2249-940 Pistons are PROBE 14477-030
Oct 28, 2010 #5 jasjamz THS Racer Joined Sep 30, 2004 Messages 5,982 Mine came out to 8.5: with cometics, same rods diamond off the shelf pistons, and iron heads the were milled for straightness. Should be fine.
Oct 28, 2010 #6 B buickgn87 Banned Joined Mar 23, 2010 Messages 208 Ok thanks guys. I just wanted to make sure before I started assembly. If anyone else has input please post. Thanks.
