Built 10 bolt 8.5 GN rear
Fat Nat
Guys I have the rear out of my race car for sale. it started out a a stock case has the tubes welded ends have been changed to big ford bearing ends to accept 35 spline axles and brakes Mark Williams 35 spline spool and axles 5/8" wheel studs T/A rear girdle all stock points with extenders on the lca mounts Powder coated black has has coil over mounts and anti roll bar mounts welded on but can be removed. Rear has been countless 1.17 60ft has 373 gear but also have 410 whichever you would like 1500 axle to axle no brakes
Thanks Jeff 410 490 8405
