Built GN motor+Tranny+ECU
motomafia
just seeing if any intrest out there .... might keep might sell or trade dunno.... everything works perfect in car now no problems. might consider trade for built small or big block and tranny local sale perferred or you can travel here. .iam in lawrenceville GA JUST CHECKING FOR INTREST
87 GN motor - J E pistons lunati custom grind camshaft APR bolts ported polished heads with aftermarket internals , motor has about 2500 miles on it... Fully built tranny with trans brake 200r4 . 3800 stall
70mm throttle body and plentnum
MSD ignition + wires
ported intake
upgraded intercooler
70 - Qtrim turbo about 800 miles on it
3" downpipe
ECU with ready to go chip
Snow performance meth injection
65LB injectors
in dash boost controller
External Delta wastegate
i was running 25psi
Iam sure there is more..... cant remember right now just wanted to see if anyone wanted to make a offer or trade Thanks e-mail Motomafia@hotmail.com
i'm not local
but i have an LT1/T56 setup i will trade
modded (fully ported heads by www.advancedinduction.com 2.0"/1.56" i have flow and build sheets,custom grind cam matched too my heads/car setup 234/242 .56x/.54x from www.lethalefi.com , SLP cold air, AS&M 54mm TB,1.6 Comp Pro mag rockers non self aligning, GM guideplates, trick flow chromoly pushrods, comp 875-16 "R" series HR lifters, Cloyes true double roller timing set, CSI e-h2o pump, 36lb blue top injectors, 12:1cr on 93 pump gas, stock untouched bottom end, Hooker 1 3/4" longtubes or a set of custom made 1 3/4"-1 7/8" stepped headers that came off a 1200hp blown LT1 car, pcm that is tuned, wiring harness and delteq coilpack ignition setup www.delteq.com. T56 is stock, has SPEC stage 2 clutch, Hurst billet plus shifter and Hurst leather shift knob
plus other things we can talk about if needed
in my 3400lb car 1st time out on 9-14-05 after tuning it went 1.73 60'...11.98et...115.62mph has ALOT left in it with more agressive timing and tweaking!!
everything is still in the car right now, i pull down 24mpg's and wont hesitate too drive it a couple hundred miles
i want too put an LC2/th200 setup in my '97 Z28 :D
but i'm looking too trade for something as complete as what i am giving up!
are you interested? you can hear it run over the phone and i could try and get video too you
Steve G.
big block motor for trade?
motomafia said:
Need Carb Motor And Th400
my buddy is trying to sell his 68' SS camaro with a 468 big block/ TH 400 trans/ 12 bolt rear end, and much,much more. my part out!!! asking $17,000.00 OBO. Run's VERY STRONG!! If interested please contact. TOM siegle4@sbcglobal.net for pic's he may also be interested in a GN trade. please contact HIM at that e-mail address. thank you.
