daredevil95
- Oct 21, 2012
Hi, I have a 86 GN and cylinders 1 & 3 aren't firing. Confirmed I have spark, fuel injectors acting funky on these 2 cylinders. Havn't dug further with injectors since I discovered cylinders 1 & 3 have 30psi confirmed with compression tester. This then made me send my inspection camera into these 2 cylinders and I found the indentations / holes? in the pistons. I attached a small video I made with inspection camera....clearly shows something but, I'm not sure if these are holes or not? Suspicious to say the least? Thanks in advance....gene
