buying the right brake pedal
blackazz
Not a Gn
TurboBuick.Com Supporter!
Hello guys,at the junk yard G bodys are had to come by.can you use a hydroboost brake pedal for vac booster.here now don't wanna pull wrong pedal
TRY-ME!!!
as far as I know the hydroboost pedal = powermaster pedal. Vac pedal is different.
Thanks didn't wanna pull it,an it not work.
TRY-ME!!!
2QUICK2B6 said:
from postons yrs ago
Is it the 84-85 hydro unit? Or a unit with the accumulator? Just trying to understand why you had to mod the pedal. Thanks
I looked for any g body vacuum for mine
I pulled off a cutlas if i remember right
There was also a monte i couldve pulled from
Cant recall if hydro wouldve worked but i think answered above
Try craigs you might find parts car someone might pull off for you
Good luck
Joel
2QUICK2B6 said:
its a hydro unit not sure of yr no acumulator ball
I see. The astro unit and the other ones people use has a small cylinder shaped accumulator on them but they mount differently. And the rod is a different length, this is why I asked as it would affect the pedal. Thanks for your info.
