I had the same problem. I just changed radiator hoses then my original radiator had broke while placing the upper radiator hose (upper outlet cracked). I replaced the original unit with new Aluminum unit, but installed a B&M supercooler. Next problem was my transmission feed-line was so corroded that it snapped off. I was hopeless at this point, so I replaced it with Bowtie-Overdrives replacement (easy to install) transmission cooler lines. Now more to the point, I called many transmission repair shops and asked the professionals here on this site and "not one" would recommend going to the auxiliary cooler itself then back to the transmission. If its a street car, then yes, a "track car only" then NO. In a hot day in traffic wouldn't cool your tranny enough with that extra cooler all by itself, without the exception of one of those coolers with a fan. That's when I learned from the experts at the shops and here that running it thru the radiator-cooler, then the auxiliary cooler itself. I too had a leak with new "lower" feed line and a new radiator, and I reiterate it was leaking too. I put teflon tape after inspecting the threads on the fitting, then cleaned it with a clean shop towel, then inspected the radiator threads, cleaned the inside-threaded area, put the teflon tape (went twice around), then to my surprise I had no leak. Mind you it took a month, new radiator and lines to get it up and running. It was a test for patience. I now thank all the men on this site and transmission shops for advice. Hope this helps.
