Here is a little more info about what I have available. I hope this clears up some of the questions.
This set-up is for mounting the 13"x1.25" C5 Corvette rotors and dual piston calipers onto the Blazer spindle that is found on any 98-02 2wd Blazer. The spindles are often referred to as ZQ8 spindles or Blazer spindles. These ZQ8 spindles will fit all 2wd S-Series pick-ups and Blazers from 82-02. These ZQ8 spindles are also a direct fit for all 78-88 G-Bodies (Monte Carlo, El Camino, Malibu, Regal, Grand National, GNX, 442, Cutlass, Le Mans) and it does require the use of 17" wheels.
Price list:
Bracket Kit $110.00 includes:
2 billet aluminum brackets
4 14mm socket head bolts for caliper abutment
4 14mm bolts for mounting bracket to spindle
Loctite 262 included
Free shipping if ordering bracket kit only.
Rotor kit (plain rotors) $70.00
1 left and 1 right plain GM Durastop C5 13" rotor
Rotor kit (drilled/slotted rotors) $150.00
1 left and 1 right drilled/slotted GM Durastop C5 13" rotor
Caliper kit (your choice of red or black new GM C5 Corvette calipers) $534.75
Includes both calipers
GM Durastop ceramic pad kit with anti-rattle clips
2 GM caliper abutments
4 GM caliper guide pins and boots
2 GM banjo bolts and crush washers
* other calipers and pads available
Spindle kit with ABS sensors $275.00 (for use on 2wd S-Series pick-up or Blazer with ABS)
Includes 2 used spindle assemblies with sealed hubs cleaned, inspected, and dust shields removed.
Includes the ABS sensors
Spindle kit without ABS $250.00 (for use on all G-Bodies or 2wd S-series without ABS)
Includes 2 used spindle assemblies with sealed hubs cleaned, inspected, dust shields removed.
Bell Tech dropped spindles and new GM hub assemblies are available
Your stock brake hoses will work but, I also recommend the Russell stainless steel braided brake line kit. $72.00 kit includes 3 hoses (2 for the front calipers and 1 for the rear axle to body)
If you have any other questions please let me know.
Jason Hurst
RPM Automotive
6411 Pike St
Mineral Wells WV 26150
304-482-1300
jasonehurst@aol.com
