Of note on this thread:
All my statements may not be accurate... this is what I remember being explained to me.
I called Turbonetics yesterday to discuss a T-70BB turbo with P-trim housing for a THDP. They said their design features a ceramic ball bearing on the compressor side of the shaft and a solid bearing (brass I think) on the exhaust side of the shaft. The exhaust wheel is made from INCONNEL (sp?) which allows EGT's about 150* higher (up to 1800-1900*) than conventional metals used in the wheels (maybe explain melted exhaust wheels from other vendors). This "70" should support around 785hp and the unique bearing/washer on the exhaust side can withstand much more thrust load than conventional non BB turbos and more than dual BB turbos they stated. Price was around $1600-1700 (can't remember)
Called Innovative Turbo today and asked the same ?'s about the same size turbo. They stated they are the only ones offering dual ceramic BB turbos and they spool quicker than conventional turbos and faster than the Turbonetics unit also which is a single BB.
*Of note: Innovative rep said the ball bearing on the exhaust side spun at 1/10 the speed of the compressor side (gear reduction or what?) and therefore had 1/10 the thrust load on it. This to me didn't make sense to me and I would like some input from you guys (Jack Cotton etc?). I also brought up Turbonetics design and they straight up said theirs is better.
How much faster spool up... I don't know.... but they said it was noticeable (marketing ploy?). They also feature INCONNEL exhaust wheels and their price was approx $2200 with a polished compressor housing included (no charge/option).
So is it worth $500 more for the dual BB setup or a Turbonetics style single BB setup?
Does the Turbonetics offering really allow for higher thrust loads without damage vs. the Innovative? Does this really come into play with our automatic transmissions (manual tranny cars normally need a blowoff valve to avoid compressor surge)?
BTW- both company reps said they have never had one of these turbos come back with damage related to thrust load on the bearings.
HELP- I need help deciding in which one to get.
Please chime in with the following:
1) whether you have a BB turbo or not and which one
2) how many miles you have on the unit and any failures yet
3) how you drive the car (% beating on it with mileage vs. cruising)
4) impression of whether you need a BB setup or not and how your spool up is with your particular convertor.
For the $500 difference in price.... I hope the justification is big... because I really wonder how much faster spool up is with a single ball bearing style vs. dual ball bearing setup.
This thread should help to start some useful info being thrown around and hopefully help us get closer to finding out the "mysteries of the BB turbo
" part VI.
Thanks,
GNX7
9's in my 2700lb car in 2003 on a T-70BB?
Thanks,
GNX7
