i finally figured out what's causing my 86 GN to perform so poorly; 2 bad cam lobes (#1 and 2 exhaust). so i obviously need a new cam. the car has the following mods:
balanced and blue printed bottom end
ported and polished iron heads and intake
t62 turbo
42.5 lb injectors with chip
3 in DP and exhaust (no cat)
built rear with stock gearing
built trans with 3000 lockup
the car had a 218/218 cam that i think was little big for the stall convertor in the car. i'm staying flat tappet since i already have new lifters and timing chain. what would be a good cam for this combo and what vendor do you recommend? the car is a weekend driver, emissions not an issue, and i'd like to put it solidly in the 11's.
t62 turbo
