I am having a terrible time with this. I put the revolution x cam kit in my motor and I set up the timing. When trying to torque the cam gear down to specs (31 lbft) the bolts continue to strip. The old bolts I pulled out of the previous cam measured to be 5/16-18 so I bought some grade 8 1/2" bolts from the hardware store and put em in, I torqued 10-15-20 fine than I got to 25 and it seemed like it was slipping a bit but the wrench clicked. So I went to 31 and the bolts just spun slowly. I pulled them out to insepct the threads and on the cam they are fine. The bolt is not bottoming out on the block because you cant see the end of the bolt when it is in all the way. So I looked at the threads on the bolts themselves and they are stripped. Almost twisted the head off one. It is almost like the thread size is wrong and the threads are a hair smaller than what it needs to be. Any one have any ideas or know what the thread size should be. Maybe metric?
Andrew
Andrew
