SignUp Now!........... What info does that cam card provide?? I am trying to find out where I get the most power, (like 5100 thru 5600) range. ............
#:69-400-8 is the part number on the cam card , I have that same cam
Nick the springs work great with the cam and does not quit anymore like you had predicted , if I could get the new SD2 dialed in , it will be a killer like you said . I am going slow in tuning it as I have installed the alky system also . I have been sorting out a few things that were needing some attention , I am getting closer , fingers crossed so far .How does your car run with the new valve springs Kim?
Ok I have a Comp Cam 218/212, I don't have the Cam card for it. What info does that cam card provide?? I am trying to find out where I get the most power, (like 5100 thru 5600) range. How do I get a copy of that card. Thanks guys
I also changed the springs in my car as it never could pull higher then 5,000-5150... It seems as if I gained a 100 hp it pulls all the way up to 5910.. The beast has finally woke up...
Do you remember the cam spring number and brand and what lock you used on your set up ?I also changed the springs in my car as it never could pull higher then 5,000-5150
