SignUp Now!Things to be aware of on a Buick V6 cam replacement:
1) Deburr oil hole on the thrust face of the cam, or it can (and usually does) wear a groove into the block thrust face.
2) Make sure you clean the cam real good prior to install.
3) use red Locktight on the cam bolt threads
4) Use a Hydraulic roller cam, not a flat tappet
5) use an oil squirt can to pump auto trans fluid into the roller lifter prior to install (through the side oil feed hole)
6) Use a hydraulic roller cam
7) degree the cam to verify that it is installed correctly
8) Use a hydraulic roller cam and lifters
9) Torque the lower pulley/balancer bolt to 225 ft./lbs
10) use a hydraulic roller cam
11) Port the timing cover oil passages
12) set the oil pump gear thrust clearance to .0005"-.0015" (TA performance has a shim kit that helps)
13) use a hydraulic roller cam
14) use a quality double roller chain
15) use a roller cam
16) pack the oil pump gears with Vasoline on final assembly
17) Pay attention to lifter pre-load and shoot for .030"-.040"
18) use a hydraulic roller cam.
19) When going with ported heads, roller cam, ect., I would suggest roller rocker arms to get your lifter pre-load right on.
20) use a cork oil pan gasket with a coating of "The Right Stuff" on both sides.
21) use a hydraulic roller cam
22) change the rear main seal while you have the oil pan off to a neoprene seal, and use "The Right Stuff" for the side seals
23) If I didn't mention it.................Use a Hydraulic Roller Cam.
24) With a hydraulic roller, there is no break in required. Start it up, check for leaks/issues, then drive it like you stole it!
25) ditch the chain tensioner as stated earlier.
26) Make sure your brakes are working good. You'll need 'em.
27) Feel free to PM me for my number for any verbal coaching you may need. But it's just nuts and bolts.
28) prime the oil pump with a drill spinning clockwise as viewed down on the engine. (a SBC oil pump priming tool works great)
29) Have FUN.
30) Use a hydraulic roller cam. (I had to add one more to make it an even 30)
I went ahead and pulled the engine out of the car last night…..that laying over the fender is not for me anymore!
