decarlo sloan
BIG S
- Mar 6, 2005
On a cam what exactly is lobe seperation ? And can you have to cams the same duration but with different lobe seperation?
SignUp Now!On a cam what exactly is lobe seperation ? And can you have to cams the same duration but with different lobe seperation?
is lobe seperation what makes a cam considered street or track cam?Lobe separtion is the difference between the intake lobe centerline and
the exhaust lobe centerline. It is measured in degrees. It is possible to
have a cam with everything else being the same except the L/S.
Dan posted on another thread he had a street combo make close to 700 at the wheels. He knows his stuff!
I think I may have some OEM cam specs at work, I'll try to remember to check tomorrow...
LSA can vary greatly between any cam profiles... In general more LSA is better for computer controlled apps as well as any type of Nitrous or Boost, but this doesn't seem to be the trend with turbo Buicks... to each there own... plus, High LSA = smoother idle, Low LSA = nasty lope
