SCOOBY DOO
BASED CANADIAN PATRIOT!!
- Feb 18, 2007
At what ET/MPH does cam selection become critical?
SignUp Now!Not reallyIf you keep RPM s low and power down low you usually have less parts breakage. More RPM = more maintenance![]()
If the person making that statement didn't mention the exhaust pressure or valve open close events he is speaking out his ass for sure. Great flowing heads or garbage flowing heads won't matter if the ex pressure is high. Running more overlap at that point will hurt you and the engine will have increased pumping losses. So closing the valves earlier and reducing overlap will actually increase power."if the heads don't flow good hold the valves open longer" or something like that. lol And that thinking outside the box worked.
...........I may be speaking out of my ass here but why does most people with a turbo buick run such small camshafts? Say if someone put a 218/218 cam in a stock head engine, bigger ar housing, and spin the motor to 6200rpm. Would the stock cylinder heads not support the flow in higher rpm? Wouldn't the engine make more power on lower boost?......................
It was something said in passing not in technical format. I do know the duration @ 500 was in the 240's, solid cam, bullseye racecover turbo with huge ar. Bp was very minimal is my guess. I was just basically wondering why there aren't many 109s trying to make power with rpm or create conversation on this topic.If the person making that statement didn't mention the exhaust pressure or valve open close events he is speaking out his ass for sure. Great flowing heads or garbage flowing heads won't matter if the ex pressure is high. Running more overlap at that point will hurt you and the engine will have increased pumping losses. So closing the valves earlier and reducing overlap will actually increase power.
There are a few. Most are running the small 3 bolt ex housing which limits turbine selection and limits the useful rpm potential because the backpressure is too high. The few that fly on the 3 bolts have figured out how to keep backpressure in check. It's as big of a part of the equation as the boost. Going with more turbine and compressor will open the potential up a lot if backpressure can be kept under 1.5:1. The compressor cover becomes a problem in some applications also and can increase backpressure itself.It was something said in passing not in technical format. I do know the duration @ 500 was in the 240's, solid cam, bullseye racecover turbo with huge ar. Bp was very minimal is my guess. I was just basically wondering why there aren't many 109s trying to make power with rpm or create conversation on this topic.
