Ok guys, weigh in. I need to at least replace a timing chain after the car just "just quit" late last summer. I have spark, fuel, erratic cranking sound, and a lil spike in the boost gauge during cranking. After I verify all 6 have good compression, I am convinced it's a timing chain.
I figured while I am in there, might as well do a cam, lifters, and valvesprings while I am at it.
I have access to brand new Crane cam that specs at .448, .472 - 204, 214 @ .050 on a 112 deg LSA.
Based on my combo (see sig) I have the following questions:
1) Is this cam a good pick? I was thinking dual pattern (heavy on the exhaust side) might help spool up at lower rpm on the street;
2) Which hydraulic, non-roller lifters do I get?
3) Which valvesprings to buy?
4) Which timing set?
5) Install "straight up" or advanced or retarded?
Any other tips, tricks, suggestions, etc would be welcome. I am going to replace the springs without pulling the heads by pressurizing the cylinders.
Thanks in advance!!!
Chris
Chris
