Cam Sensor +5V ???
dereklola
IndyLights
Does the cam sensor (25516915) need +5V from the ECU?
- red wire - +5V
- blue wire - signal to ECU
- black wire - ground.
Or is +12V or some other value?
I'm wiring up the above part into my Indy Lights restoration but using a non-Buick ECU.
Thx - Derek
Cam sensor getsa filtered 11 to 12V from the CCCI module.
Terminal A +,
Terminal B Signal,
Terminal C Common (GND).
John
Aha - glad I asked - so it's 12V not 5V - thx.
My ECU has 5V, 8V and 12V pins so I guess I'm OK
Derek
