Ok well some of you guys will know to check here and some won't,I overlooked it so I hope this helps some of you guys that run into this issue.
I was fighting a drivability issue with my car for weeks...this was just after rebuilding it from a head gasket thrashing. Anyway....after getting it running the car would start and idle smooth,when leaving the house it would break up real bad under very light throttle and then seem to clear itself up after it got warm(about 10min)
This one really got me! At first I checked all the simple stuff that you would figure,coil pack,plugs, ignition module fuel,grounds,etc.....on and on as I said this had me for weeks. I then thought I had some bad gas due to some other buddy's telling me they had issues where I fueld up. I drained the tank ...new gas, no change. I pulled my cam sensor inspected and reset...no change
The car acted like it had bad gas or like the timing was way advanced and what really stumped me was that it really cleared up after it got warm. Not completely but to the point that you could accelerate and it not pop spit or sputter. It only acted up under 6psi or more.
Well I swore it was some type of a timing issue, inspected the cam sensor cap again and found a tiny hair line crack. I had a spare sensor so I threw the cap on and went for a drive. It seemed to fix it......but no it cam right back. I pulled over on the side of the road and unplugged the cam sensor and BOOM! the car woke.
I wnet back to the house and put my spare cam sensor in, before that I laid the old one next to the spare. The only thing I could find was the original one has the slightest bit of play in the shaft. The first time I inspected it I thought it was normal. I was wrong that lil bit of play was causing all the issues!
So if you run into this weird running issue like I did, pull that cam sensor and look it over very closely!![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
