I pit cam sensors in several dozen times and never had any issues. However, I've just started putting my engine back together after fresh rebuild. I fought with lining up the cam sensor for a bit and now have in place. Now that its in its very hard to rotate while using my caspers cam tool. I'm having to use channel locks to rotate! I did lube the o-ring before I inserted into hole. Should it be that hard to rotate? Do you guys think something isn't lined up correctly? Or should I not worry and go with it?
Thanks in advance
FYI, motor is on engine stand
Thanks in advance
