LAMMONS0003
- Nov 11, 2010
I just replaced the cam sensor on my car with a Caspers cap. The light never lights even when rotated 360 degrees. I have 10.9 volts on the power wire. I have 6 volts on the trigger or signal wire all when it approaches the cut out spot in the interupter ring. A concern of mine is even when the cap is completely removed from the sensor shaft the LED never lights and signal wire still has 6 volts. While the cam sensor is on a solid part of the interupter ring voltage goes close to battery voltage or 11 volts. I have used my original ignition module and bought an adapter to 86/87 and tested with another ignition module. I am out of ideas???????
1984 Buick T Type only modifications are caspers cap and small camshaft kit.
