ChrisCairns
Senior Member
- May 24, 2001
What do the words "cam sync" mean on the all sensors dashboard?
I've spent the day trying to get my T-Type running. Put my returned turbo on it, started it up, it idled for 1 minute then suddenly quit. No spark.
FAST shows an rpm signal plus I put my cam sensor tool on the cam sensor, turned the engine over and it flashes. Even took the sensor top off and the wheel was in place and turns. Changed coil/module. Checked both original and replacement with Casper's checker. Checked all fuses. Checked relay to FAST. Checked wiring as far as I could. Ruled out crank sensor due to rpm signal to FAST.
I'm stumped. As I said though, FAST doesn't show a cam sync while attempting to start.
What's cam sync ?
What's cam sync ?
