Nov 29, 2002 #1 F fast4d New Member Joined Jan 13, 2002 Messages 55 I need to goto an aftermarket engine management on my bmw. It has a coil for each cylinder (6). I'd like to use FAST since I'm familiar with it. Can it control 6 coils? I believe the factory system use a crank position sensor.
Dec 2, 2002 #2 C Craig Smith That was easy! Joined May 25, 2001 Messages 1,147 I don't know if the factory crank sensor will work with the FAST but 6 coil control can be done with an eDist. There are several other posts on here regarding this topic you should probably read.
