Flyin Brian
- Jun 18, 2011
I just got a new EGT gauge (AEM) with a 0.5 to 4.5 volt analog output so I could have a gauge and log EGT's to my Powerlogger. Problem is that the Powerlogger EGT reading is way different from the gauge (around 300 when the gauge shows 100). I tried messing with the offset but it does not fix the problem. I think the problem is with the scale. Is the Powerlogger EGT scale for 0-5 volts? If so, can I change it and how? I looked in the INI file and so not see any place to change the scale for analog channel 3. Thanks for your help.
