Jan Larsson
- Nov 22, 2001
SignUp Now!I think the tranny lines go thru the crossover and block, thats the hangup.
If you install flexible trans lines, then your good to go!
That motor looks great!![]()
BW
You should have built the oil pump assy with the cover off the motor. Also prime the engine on the stand.
HTH
Hi Jan,
Long time since I talked to you! You have done wonders since then with your project.
I think you are going to have some issues installing this motor WITH the crossover.Better that you leave it off, and fit it after installation of the engine. The subframe will give you trouble, certainly.. There may be other problems; trans cooling lines were already mentioned.
I wish you the best of luck with the continuance of your wonderful project!
Dale
Hi Jan!
No! You have to install it after the motor is in. There's not enough clearance to pass the K memeber. The trick to getting it on right is to leave your header bolts loose. You can then match it to the headers correctly and go back and tighten the headers. This is especially true if you used gaskets on your headers.
