When I put an SS governor in my trans the shift points whent from 5,000 to 5,500. To bring it up to 6,200 I put a stiffer spring in with the TV limit valve. Shimming it,as Chris suggests,will accomplish the same thing. Try both so you can see what happens for yourself. Then you can post your results. Try one then the other so you can learn how effective each is.
