can you identify this mystery spring for a 2004r for me
Warrant
While I was disassemblying my 2004r, I was about half way through the tranny internals, and Im pretty sure I had the vavle body off by when I found this spring laying on the ground.
I dont know where it came from, its a light spring, not a whole lot of force, kind of dark greenish bluish in color.
Its the smallest spring in the picture, other stuff is just for comparison
Any ideas? :confused:
could be the accumulator vavle spring. just put a shift kit in last night. . .
That is the TV blow off spring. It goes on the cotter pin looking thing on the TV linkage.
The other springs look like 3-4 accum springs. The little one maybe went down in the case, then the piston, then the bigger spring.
Mike
in the pic above the L end goes underneath the letter A on the bracket where the tv cable goes into correct ? If thats the way it goes is it normal if looking at it from the same angle in the pic above for thre pin to be cocked to the left a little ? Any help is greatly appreciated actually can u install it onto the tranny the way it is in the pic above ? or do you have to insert the spring and stuff while going to mount it on the tranny
Yes, it probably won't look straight.
Yes, assemble it first, then install it.
