Cannot remove timing cover!!!
87gninpa
have all ofthe bolts out, including the 3 on the pan, and the thing wont budge. is there anywhere i can pry to get it off?? ive been pulling on it with all of my strength, do they normally have this had of a time coming off?
Not normally a tough pull even with the timing cover alignment pins in place. Get your super-zeon-zapper work light out and light up the cover from all angles (especially below) to make Sure you have all the bolts out. I'll bet one is hiding on ya. :)
HTH - Jimmy
There is a bolt in the oil pump area the is elusive 2nd up on the RT side it's recessed. Also take the bolts out of the water pump.
i guess all of the grease that was built up was holding it in place.....after some gentle prying, it came off......thanks for the help guys
