After putting in new body bushings, I can no longer get the ignition key out after putting the car in "P"ark. I have to grap the steering column and rotate it just a little further, then the key comes right out.
I suspect now that the body is up just a little higher off of the frame now with the new bushings that there is something I need to adjust on the shifter cable, but not sure where to adjust to get the desired results.
Thought maybe someone has ran into this before and has a easy way to fix without me dorkin around with it for hours.
Thanks,
Thanks,
