You will need to adjust the boost yourself. The boost written on the chip is what the chip is calibrated for, with regards to fuel and timing. It doesn't mean the computer will put the boost at 23-25psi, as it doesn't have that capability.
When you make the wastegate rod shorter (tighter), the boost will go up. One turn is usually around 1psi, but you'll have to experiment with it.
Regards,
Eric
