Jan 5, 2014 #1 F futten Active Member Joined Mar 19, 2010 Messages 681 anyone here know if i can use rotors from a 1991 caprice on a 80s caprice spindle with stock style caliper? the spindles already came with 12" ( roughly 12") rotors
Jan 5, 2014 #2 N nonosv6 Member Joined Jan 8, 2002 Messages 757 I believe the caprice rotors have a 5x5 bolt pattern vs 5x4.75. I think you need to use the 1le rotors from an 82-92 fbody. Joel
Jan 5, 2014 #3 F futten Active Member Joined Mar 19, 2010 Messages 681 uhm ok? i wouldent think that the f body rotors would fit a b body spindle
Jan 5, 2014 #4 N novaderrik Well-Known Member Joined May 12, 2004 Messages 8,076 you need the 90-92 Camaro 1LE rotor- which is based on the 12" Caprice rotor with a different wheel bolt pattern and wheel pilot diameter.
Jan 5, 2014 #5 F futten Active Member Joined Mar 19, 2010 Messages 681 from what i can find theyre all 10.5 "
Jan 5, 2014 #6 F futten Active Member Joined Mar 19, 2010 Messages 681 well atleast with timken the 91 caprice and camaro share the inner and outer wheel bearings so
Jan 5, 2014 #7 S SFI Cutlass Active Member Joined Jan 2, 2010 Messages 367 http://tech.oldsgmail.com/sus_bbrake.php Posted from the TurboBuick.Com mobile app
Jan 5, 2014 #9 M mybuick intercooled engines rule! Joined Jul 21, 2002 Messages 1,502 i have the s10 dual piston calipers on my gn and i do have a low pedal. what the link doesent say is what year for the b-body master cylinder to get?
Jan 5, 2014 #10 F futten Active Member Joined Mar 19, 2010 Messages 681 i think all the g body cylinders are the same
Jan 5, 2014 #11 S SFI Cutlass Active Member Joined Jan 2, 2010 Messages 367 Read it again says what years and you can choose cast or aluminum. Posted from the TurboBuick.Com mobile app
