RegalT-type85
- Jan 23, 2010
Sorry buddy it wasn't the cat. I agree now with Cam/crank/ MAF sensor. If cam sensor is loose or faulty it would throw the injectors timing off.Faulty MAF same thing. I see it runs fine at low speed, at WOT "pops" so could be loose sensor or faulty. At idle car vibrates little at WOT well if it's loose throw the sensor off .
If it is the MAF it's bes to upgrade to the Lt1/ls1 maf & translator.
If not sure a few have a spare laying around or few sites have them in stock.
Check all your sensors that have anything to do with controlling your fuel/timing etc.
IMO, correct me if i'm wrong, if your map sensor is faulty anything above so PSI it wouldn't read right or add fuel.
I believe MAF/Cam sensor control timing of fuel injection, map controls the fuel mixture. If i can recall
So if your at WOT and getting 10lbs of boost(ex) the MAP sensor only reads 5lbs then I can see why at WOT it wouldn't add fuel or something along those lines. Might even be a 1bar MAP, Get the part # on that.
Again hope its nothing major buddy. Take care.
