Hey Guys, hope you can help me out on this. Haven't driven the GN since Tuesday, had the K&N off to do a cleaning. Got it put back on today (cleaned it tuesday night, let it dry until Thursday and oiled it thurs. also). It idled bad all day, then on the way home, it died (In a really bad spot
) Before it died, I had gone thru the drive thru at sonic and while idling, it died twice but started fine both times. Anyways when in died going up a steep hill on a two lane road it wouldn't start. Got somebody to pull me up the hill onto the side of the road and around 20 minutes later it started. Idled even more rough, but it got me home. The SES light was on the whole way. Checked on DS and it was code 41, the Cam sensor. So I replaced top of cam sensor and it was the same. SO, in the past hour I've swapped out most of the parts off the Iroc to try on the Buick. Things I've tried:
Top of cam sensor
O2 sensor
MAF sensor
Ign. module/Coil pack
ECM
Car still idles bad, and dies at idle. BLM's at idle is down to 90. IAC counts seem good, and both MAF's showing 6 at idle. Of course this has to happen the night before most of us here in Albuquerque/Rio Rancho are going to go to the Strip
Help!
Top of cam sensor
O2 sensor
MAF sensor
ECM
