SpoolinV6Turbo
- Jan 17, 2005
To make this short, went into Best Buy the other day and when I came back to the car she wouldn't turn over without the help from the jumppack. Turned out battery wouldn't hold a load, the negative cable was poor, and the high torque starter was toast. Now got a Optima Yellow Top, new ground wire, and new high torque starter.
Turns out the same situtation is still happening even though tests did show all those parts where bad. The car will start up without a problem for the first time of the day. When driven for about 2 miles or more, after the engine is turned off and you wait 10 minutes, the car will not crank over. When it's hot it will crank for about 45 seconds, backfire, tries to lockup. After doing this 2-3 times, the engine will start up like NORMAL!!!!
Crank and cam sensor are fine. Any ideas
