Mar 29, 2013 #1 R riviera Member Joined Jan 7, 2012 Messages 219 My car has a funny mis at idle and it lopes like it has a big cam in it.truthfuly I like the way it sounds but I know its not right ive change the plugs wires and coil pack.has any one else had this problem and what did u do to fix it
Mar 29, 2013 #2 Phoneguy Cometic HG stress tester Joined Aug 27, 2002 Messages 6,888 Bad injector/harness, wiped cam, broken valve spring/rocker shaft? You need to start checking somewhere. Bryan
Mar 29, 2013 #3 R riviera Member Joined Jan 7, 2012 Messages 219 I dint think it would be so serious it runs good while driving but it has a slight mis at idle or relight
Mar 29, 2013 #4 Phoneguy Cometic HG stress tester Joined Aug 27, 2002 Messages 6,888 Could be as simple as the IAC valve, bad spark plug, MAF, etc...you wont know until you investigate... Bryan
