good luck , youll need it without any signs of working up the tune before hand and challenging another car (well two pontiacs) at the track
what was the boost you ran for the 12.4 slip ? did you fix the trans issues or just the converter
and what was the reason for the 1.9 60
if this was at 24# i can see the posts on the internet already how a gto and a ta spanked a GN
on your chip settings for the 5.6TT
144/128/132/136
is the chip burned for the 49 or the 61?
144 good start for wot ..start rich work back , but you need to work the boost up not just go at it with 24# and see if she'll hold.. by increasing WOT 16 clicks you also increase 1st gear the same , you have 1st fuel at 128 which is now also the same 16 clicks (12% or so) richer than as eric sent it , this may lead to slow spoolup and lousy 60' from all the fuel so dont expect much on the launch until you experiment with dropping it back down toward base
as a rule what you add in wot you must remove from 1st to return 1st back to base or 112 if wot is 144, if chip was burned for the 49 I might try add 5% over what i had run before with the 49 turbo again start rich and work back , ive had cars go 1.7x's and then after retweaking the 1st fuel to actual base (take out whatever was added by wot) go 1.52s , thats why eric put 1st gear fuel control in the chip
you also upped the timing 1-2 by a little and 3-4 by over 2degrees, timing should only be upped once you reach your boost you want to stop at and have the fueling sorted out for best mph with zero kr
