Possibilities
If engine almost starts and possibly backfires, make sure the cam sensor is snug. Also take the cap off to make sure the screw for hall effect piece is tight (might need red Loctite).
If the engine starts to fire and then dies or takes extra-ordinary throttle manuvers to keep running, check mass air flow sensor.
If the engine does nothing but turn over without a hint of firing, crank sensor suspect.
