Yesterday was driving home and car just died no boost just idling and then nothing, tried restarting but nothing, just cranks. Towed it home worked on it today no spark, so I changed Crank Sensor checked all the fuses they are fine tried cranking it over still nothing but I do have spark now, and it smells like fuel I am thinking that the relay is acting up for the fuel pump because when you turn the key on you can hear the fuel pump running all the time with key on, isn't it supposed to pressurize the system then stop, O.K key on fuel pump pressurizes then you shouldn't be able to hear it right, the
fuel pump is constatly running is this normal? checked cam sensor cap it looks good, as well as the little screw on top, I recently changed the oil pressue light sending unit but the wire connector was all mangled so I pulled it off and just connected the wires to the sensor could I not have the wires on the right terminals, or could this be a bad ignition module???? I am lost please help
