b4black
- May 24, 2001
I thought everyone here might be interested in this. Car Craft has an article called "Fueling a Controversy: Carb Vs. EFI"
The first sentence is "There's no doubt that EFI has superior part-throttle driveability and offers greater potential for fuel economy, but car crafters don't build motors to go to the grocery store, engine dynos and dragstrips aren't run a hlaf throttle and if we cared about mileage we wouldn't be building big-cam 454s with double pumper carburetors."
They then went on to test a 454 crate motor will both EFI and a carb (same intake). The result was a tie.
Carb: 454.4 hp/490.3 lb-ft
EFI: 454.4 hp/491.8 lb/ft
So their conclusion: "....showing that properly dialed in, both the carb and the EFI get the job done under full throttle. But which will start right up on Christmas morning in Anchorage? Our bet's of the fuel-injection. On the other hand, you'll spend around $5,500 (including ignition and special throttle body) for a big-block Chevy EFI setup like this. Advantage, carb."![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
No, I'm not trying to say the a Carb/Turbo is just as good as a SFI/IC/Turbo. But I think this shows that a carb in itself is not a bad thing. We just need more time to figure out what works and doesn't work.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
